Radio antenna base removal
Posted: Wed Oct 29, 2008 7:57 pm
by MB300GD
How do I remove my radio antenna base that is part of my canvas top? Then do I need to repair the canvas top after removal?
Posted: Wed Oct 29, 2008 8:40 pm
by ka
it just unscrews but often the inserts spin if the bolt is rusty. and yeah, holes in the top are left, but easily patched.
Posted: Wed Oct 29, 2008 9:12 pm
by Jim LaGuardia
Most guys make a metal plate and use black silicone sealant to put over the hole
Posted: Wed Oct 29, 2008 11:43 pm
by ka
one thing i learned about silicone adhesive is that it out-gasses in the sun, so it shrinks, so the bond line breaks and h20 gets thru. latex house calk (sealant) or "geo-cell" work gr8.
Posted: Thu Oct 30, 2008 6:19 am
by MB300GD
thanks - the Pinz won't fit in the garage with the base on
Posted: Thu Oct 30, 2008 5:59 pm
by NC_Mog
Sure it will. You'll just knock the garage door off its track, rip the arm off the door that the opener attachs to, and damage the door trim.
Not that I would know anything about it; I just heard about it from a "friend".
Posted: Thu Oct 30, 2008 6:09 pm
by ka
HMMM. PINZ AIR.
Posted: Sun Nov 02, 2008 11:29 am
by norcal pinz
my hardtop has a homemade piece of metal with silicone covering the antenna hole and it leaks i want to order the original cap and gasket for mine
Posted: Mon Nov 03, 2008 8:04 pm
by Lightningpinz
After I took the antennea base off, I now only have to add 12 bags of sand to the rear and let the tire pressure down to 15psi. Viola It only rubs on the weatherstripping on the door frame.
Posted: Tue Nov 04, 2008 10:06 pm
by M Wehrman
******After I took the antennea base off, I now only have to add 12 bags of sand to the rear and let the tire pressure down to 15psi. Viola It only rubs on the weatherstripping on the door frame.*****
Unless you are into body building and to go anywhere you will need to air up.....how about 5lbs ,and 5 bags
Posted: Wed Nov 05, 2008 8:23 am
by LibTimothy
I think you all are missing the most important point here.
You guys need bigger garages! Just explain to the wife - Big truck = Big garage. I'm sure she will understand.
Timothy
