Steering Bos Info
Posted: Thu Jan 29, 2009 8:54 pm
by Doug Lennox
Still trying to work out the year of my Haflinger. I have found a decal on the side of the steering box which has the Fabr Nr. as 534249 7 69. Would that mean that the steering box was made in July 1969 and does this line up with the Haflinger year model? Any info would be muchly appreciated. Thanks
Posted: Fri Jan 30, 2009 11:56 am
by rustywheel2004
Hi Doug,
Someone may correct me on this but I'm quite sure there is no relation between the steering box plate and the Haflinger numbers. The steering box was an OEM item purchased under contract by Steyr-Puch. The numbers look similar by coincidence only as this was a common format used by many manufacturers at the time. The "7 69" may indicate a dateline but likely does not. If you post the motor and/or chassis number for your Hafi I may be able to give you an approximate date of manufacture from my database.
Steve
Posted: Fri Jan 30, 2009 3:29 pm
by Doug Lennox
Steve,
The engine number is 5362991 and the chassis number is 5361250. I have had a bit of feedback from Haflinger Technik and they beleive it to be 1969 or 1970. The reason that I am trying to find out is because the VIN plate is missing. I was told by the person I bought it from that it was a 1966-7 vintage.
Posted: Fri Jan 30, 2009 10:39 pm
by rustywheel2004
Hi Doug,
Dale is correct with the date of your Hafi. It was built in early to mid 1970. Your numbers are only a very few newer than my truck which was built late in 1969 (confirmed by Steyr-Puch). The MoT here had registered my Hafi as a 1971 as that was the year it was first sold as new. Other than some early Series 1 type, I have never seen an original build plate that included a date so even if you still had yours it would not likely have helped you. Incidently, I saw an eBay listing somewhere this week with new build plates for sale.
Steve
Posted: Sat Jan 31, 2009 1:16 am
My 71 NA 700AP Bug eye Haflinger has the production date on the dash tag along with the vin number and DOT conformity statement.
Do any other non US Bug eyes have a dash tag too, or it used on US models only?
Posted: Sat Jan 31, 2009 8:17 pm
by rustywheel2004
Hi Jim,
The conformity tag is on US Hafi's only. It was applied after the truck arrived stateside. The date stamped on this plate is when the vehicle landed in the US and may vary somewhat from the actual date of manufacture. The adoption of the plate began about 1968 or 1969 along with the US rules for more side reflectors, heavier roll bar, reverse light and 2 circuit brake system. The US "Bugeye" Haf is different from Canadian Bugeye's in several respects due to these regulations.
Steve
Posted: Mon Feb 02, 2009 3:15 pm
by francislandry
Steve,
I have a 72 NA 700AP and was wondering what all the differences were between the US and Canadian versions were. Do you know what all the differences are?
Francis
Posted: Tue Feb 03, 2009 7:44 am
by rustywheel2004
Hi Francis,
The differences between US & Canadian Bugeyes are subtle prior to 1968. The US adopted new vehicle minimum standards in 1968 which forced changes to all new Hafis arriving stateside. Canada was much slower in tightening things up. Here is a list of the major differences, some of which were due to regulations and some due to the primary importer's preference.
-US used vertical mount Lucas L795 taillights whereas Canada had horizontal Lucas L691
-US have a 2 circuit brake master cylinder on later models
-US have circuit breakers (importer preference). I have only seen 1 Canadian Hafi (polycab) with breakers.
-US have a heavier square tube roll bar (Swiss army)
-US have medium rate rear springs (as used on 703AP) on all models
-US have rectangular side reflectors/indicators on both front & rear. Canada has small Carello button type side indicators on the front only
-US have rear mount reverse light
-US have 2-speed windshield wipers on later models
-US have 4-way emergency flashers on later models
-US models have a vehicle US conformity data plate installed either on the left cowel side or dash (installed by importer)
I think that covers most of the key points.
Steve
Posted: Sun Feb 08, 2009 6:59 pm
by rustywheel2004
Two other differences that I forgot to list are:
-US have a tubular front bumper on later models
-US have "Pathfinder" badging on later models
The Canadian importer sold several Haf's to US customers and still more made their way to US homes later. Thus late model Canadian spec Haf's are commonly found in the US.
Steve
Posted: Sun Feb 08, 2009 7:12 pm
by Profpinz
They are also found in Australia, as when SDP notified their worldwide distributors that Haflinger production was to/had ceased, Barry Jones (the Australian Haflinger and Pinzgauer agent) managed to get a shipment of 30, US specification built Haflingers "side-tracked" to Australia.
The very last Haflinger sold new in Australia was actually a US spec vehicle.
Posted: Mon Feb 09, 2009 7:40 am
by rustywheel2004
Hi Peter,
I've noticed that some of the data plate numbers on Haf's in Australia are VERY close to some of our local machines in Canada. I assume that these Aussie machines were from the re-directed shipment.
Steve
Posted: Mon Feb 09, 2009 3:29 pm
by Profpinz
G'Day Steve,
I'd guess a lot of the Haffy's in Canada and the US are virtually from the same production lot / "family".
The last Haflinger sold in Australia was not actually assembled until some years after production had ceased.
I remember regularly visiting the Australian distributors in the 70's and early 80's (to get parts etc for my Haffy etc) and seeing the CKD package sitting up in the storage area above the office.
That same vehicle was sold at an auction in the country about 10+ years ago, but I lost track of it after that, however I believe that same vehicle may now belong to a gentleman in NSW.
Posted: Mon Feb 09, 2009 4:26 pm
by rustywheel2004
Hi Peter,
That Hafi was probably the last new unit sold anywhere. It would be very nice to keep track of it and ensure it is preserved.
How are the Hafi numbers holding up Downunder? You had about 740 imported in total. That's pretty good odds that there should be quite a few remaining. They're getting very hard to find here in Canada now.
Steve
