710k body ?
Posted: Fri Mar 27, 2009 10:18 pm
by norcal pinz
can i unbolt the top half of my 710k i need to do some work in the gap. Water gets in in some spots it looks like if i unbolt the bottom half of the windshield i can take it off in one piece all the way to the back? i was only going to jack it up maybe a couple of inches and work on it from there? does any body know what kind of stuff is in between there?stretchy tough glue? !!!!!! thanks everybody!!!!!
Posted: Fri Mar 27, 2009 10:43 pm
by Erik712m
Goo and weather stripping. Easy enough to put it back together. Just remember there are bolts on top of the window frame all theway to the corner.You can take it appart at the top. Not sure if I would try to take the top and window frame off at the same time?
Posted: Fri Mar 27, 2009 10:54 pm
by norcal pinz
i know there are wires, i wonder if there is enough play in the wire length to not have to disconnect stuff? i have all the original equipment lights and stuff.
Posted: Fri Mar 27, 2009 10:58 pm
by Erik712m
Wires yes for lights. Mine came unplugged but it looks like there color coded. Easy enough toark unplug and plug back in when you're done.
