fuel guage wiring
Posted: Thu Apr 16, 2009 7:58 pm
by norcal pinz
i just bought a new fuel gauge from SAV the back is very dif from the factory one.which wires go where?
Posted: Thu Apr 16, 2009 10:28 pm
by Jim LaGuardia
Gee, is this a trick question? I know there is usually an instruction sheet in the box and the terminals are even marked :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll:
Yes, that was sarcasm :shock:
Pinz content below:
S= sender wire(purple in most cases)
G= ground(Tan wire to green terminal, Not the case)
+= power (black)
Posted: Fri Apr 17, 2009 1:09 pm
by norcal pinz
this is what i got
two black wires----------positive
one grey wire[maybe purple?]------sender
but then there are 4 red wires!two on the left mounting pole and two on the right
and on the back of my new one there is only spots for pos+
neg- and sender? the only thing i can think is that i just reattach the 4 red wires onto the mounting poles? please help. the instructions i got only do not even mention the 4 red wires in the dash are these wires the ground for the dash lights? :?
Posted: Fri Apr 17, 2009 2:53 pm
by Jim LaGuardia
Sounds like somebody used red wire for grounding other items.
You would be wise to trace these back to the sources to verify circuit as light brown is the factory color for ground wires.
And once again, those go to the GREEN terminal NOT the case or mounting lugs :wink:
Posted: Fri Apr 17, 2009 4:11 pm
by norcal pinz
im going to give it another go tomorow?Is there a way to test the sending unit?thank you so much!!!!!!!! 8)
Posted: Fri Apr 17, 2009 4:56 pm
by Jim LaGuardia
The procedure is in the repair manual. You will need an ohm meter.
Posted: Fri Apr 17, 2009 5:35 pm
by loyalp
Hey Jim, I finally bought one of these SAV units and replaced my faulty fuel gauge... it's only been what, 2 years since we tested it out as bad at the Pinz meet?
Haha.
All that said, my wiring was stock so it was pretty easy to swap it in. Sounds like norcal has a different setup.
Posted: Fri Apr 17, 2009 6:38 pm
by norcal pinz
mine looks stock it also has the engine hour meter next to it .being color blind does not help either :P gonna give it another go tomorrow thanks guys
Posted: Sun Apr 19, 2009 7:56 pm
by norcal pinz
all good :D the gauge works and looks nice too thanks.just have to calibrate it.
