Bushings for carb shaft play
Posted: Tue Jun 09, 2009 9:09 am
by milesdzyn
I need to re-bush my carbs and can't find any info on the proper size bushings to use. Anyone done this before and have a size and source for them.
The process seems straight forward and I have all the tools needed for the job.
Miles
Posted: Tue Jun 09, 2009 2:56 pm
by todds112
Miles, there is an oversize steel shaft available. My old shaft was brass and had visible wear. I used the oversize shaft and it took care of the slop. Apparently there is a throttle base version that was machined to accept seals. I think Denis at Linden Engineering was also machining bases to accept seals.
It really helped with the gas leakage and being able to sync the carbs up.
Here's the post I made about it with pics:
http://real4x4forums.com/PinzgauerBBS/v ... ttle+shaft
Hope that helps.
carb bushings
Posted: Tue Jun 09, 2009 8:26 pm
by pinzdriver
Take your carbs apart and take the bases to any carb rebuilder and they should be able to rebush them for about $50.00 ea. :D
