Long drive and knuckle seals are leaking
Posted: Mon Jun 22, 2009 9:36 am
by audiocontr
I did a long drive (8 hours) and i see the front knuckle seals are leaking. I had originally thought it was the brakes, but nope, Jim L is correct javascript:emoticon(':P') How difficult is the repair? Can i apply lube and hope for the best?
Posted: Tue Jun 23, 2009 9:07 am
by pinzinator
Heat may have built up and the seal acted as a pressure relief valve? Check the oil level in the hub, and tighten the seal ring. Not too tight, it just takes a small allen.
Posted: Tue Jun 23, 2009 9:29 am
by audiocontr
Thanks much!
Posted: Tue Jun 23, 2009 12:06 pm
by audiocontr
Where do I check the level of fluid? I'm under the truck as I type. If anyone can help, give me a ring. 716 510-6333
