Chirping
Posted: Sun Sep 06, 2009 3:55 pm
by jkslvr
Has anyone experienced a chirping sound when their foot is not on the clutch. Sounds like a belt chirping?
It is not loud, nor does it affect performance, just a sound, If I just lightly touch the clutch the sound goes away.
Posted: Sun Sep 06, 2009 11:47 pm
The release (T.O.) bearing is starting to fail :wink:
Posted: Mon Sep 07, 2009 10:19 am
by jkslvr
Anyone have an idea on the cost to fix it?
Posted: Mon Sep 07, 2009 11:45 am
by NoahDL88
From Expedition Imports the price of an entire clutch kit is around 700 when you add up all the parts. I don't know about the Pinz specifically but if I was going to get in there for one part i'd replace them all.
Plus about 2-4 hours labor and you've got a Saturday afternoon into it.
You could probably just throw in the bearing, but do you really want to find that your clutch is about done and have to wait on the other parts for to come in?
Posted: Mon Sep 07, 2009 3:43 pm
The throw out bearing is around $160 if I remember correctly.
Takes about 2-4hrs to replace. A very easy job if you have common sense and average mechanical abilities 8)
Use a graphite based grease to lube the guide and fork ends :wink:
Posted: Tue Sep 08, 2009 11:21 am
by Twin Pinzies
I have a slight "chirp" when I release the clutch before it gets driven around a bit. It hasn't gotten any worse in two years though!
Posted: Tue Sep 08, 2009 11:51 am
by jkslvr
The sound I have is constant. When I drive it just goes along with the engine speed. if I rest my foot on the clutch very lightly it stops. So it is beginning to fail. Time to take it to Dennis. Bummer.
Posted: Fri Oct 09, 2009 12:54 pm
by norcal pinz
it might be the same chirping i just fixed on mine it was the starter backplate remove the seats and the whole engine hatch start the motor and grab the starter w your hands and wiggle it, if it moves even a little bit and the sound goes away its probably that replace the backplate and make shure its snug!
