clutch slave
Posted: Mon Oct 05, 2009 2:25 pm
by norcal pinz
O.k. so i removed the clutch slave and the starter went in just fine but when i put it all back together the clutch wasn't engaging very well or not at all. My question is do i need to readjust the clutch now that i have removed and reinstalled the slave? what could cause the clutch to be not working thank you very much
Posted: Mon Oct 05, 2009 6:54 pm
by Profpinz
No, it should be fine if you reassembled it properly.
Silly question, but did you correctly relocate the clutch rod back in the slave when you reinstalled it???
Posted: Wed Oct 07, 2009 4:40 pm
by norcal pinz
i guess i did not have to check this weekend
Posted: Thu Oct 08, 2009 9:07 pm
by norcal pinz
i checked today and everything is connected right but my clutch still isnt working now what do i do??? :?: thanks .
Posted: Thu Oct 08, 2009 10:15 pm
by milesdzyn
When you grab the clutch fork does it wiggle or is it solid. Other than that try bleeding the system and checking for leaks in the system.
Miles
Posted: Fri Oct 09, 2009 7:09 am
by pinzinator
Remove the transmission cover in the bed of the truck. On the top of the bell housing you will see a removeable plate held in place by 2-10 mm nuts. Remove that plate. Watch the motion of the clutch rod as someone pushes in the clutch. It will be quite obvious if something is missing or out of place.
Posted: Fri Oct 09, 2009 12:49 pm
by norcal pinz
I already visually inspected the fork through the hatch and everything looks fine i was alone so i had nobody to push the clutch but it looked all good so if everything looks normal in there does this mean i have to replace the clutch? the sad thing is it worked fine before i fiddled with it
