Heater Duct?
Posted: Sat Oct 10, 2009 7:20 pm
Hi All,
I took the exhaust system out of my 710 today to replace the slip joint, muffler, and transfer case shift cable (toasted from the leaking muffler). I thought that while I have the exhaust out now would be an opportune time to replace my heater ducting. My truck never had good heat and last winter it had no heat at all.
Patrick at CWR once suggested using silicone ducting like that used on aircraft and racing cars. It's expensive but has some R factor and it stands up well to excessive heat. Has anyone tried this? How about a source?
Also, I could use the duct lengths and sizes or at least a some input on how much and what size duct to order. Mine is in such bad shape I probably can't get very accurate measurements.
Does anyone have any other suggestions for replacing the heater duct and a source?
