#3 cylinder burning lots of oil
Posted: Mon Dec 07, 2009 11:29 pm
Is there anything in particular with the Pinz engine that could cause a large and sudden increase in oil consumption in one cylinder? Here's the back story:
My 1973 710M sat for roughly a month until I went to fire it up and found it only wanted to run on two cylinders. After a little diagnostic work, I figured out that the rear two cylinders weren't firing, which obviously leads you to the carburetor. It turns out the float was drowned, so the carb was just dumping fuel into the cylinders. I swapped in one of my spare floats and it ran beautifully....
...except after a couple minutes it started blowing blue smoke out the tailpipe.
And tons more out the joint in the exhaust headers. I shut it off and took a closer look, and engine oil is dripping out of the header joint, and the hot exhaust is obviously responsible for the clouds of smoke. I determined it's coming from the #3 cylinder.
So, before I pull that cylinder head off, is there anything I should know or be on the lookout for?
