Oil Thermostat Alternate
Posted: Thu Dec 17, 2009 9:20 pm
I had troubles getting my engine to warm up, wrapped the whole lower crankcase and oil pan with aluminum bubble insulation.
Picked up about 15 degrees... now up to about 140 F.
This is so low that you may develop foamy oil, the engine doesn't get warm enough to cook out the combustion condensation that inevitably get into the crankcase.
A friend at work was restoring am old Porsche 911 and showed me a slight oil leak that he had, and I saw his thermostat. Wow
it looked just like the one on the pinz. He was kind enough to remove it and let me take it home to compare, physically identical! I did some research and the numbers from the manufacturer indicated the it was right in the temp range for the pinz.
So, to keep this short we found a good used one online ($35.00)
at one of the MANY online Porsche sources.
It works flawlessly, perfect fit. Now I can get my oil temp up to 175 F. with an outside air temp of 28 F.
I installed it in last March of this year and have run it all summer,
185-190 F. with an outside air temp of 100-110 F.
Pinz #7101070260U Replacement
PORSCHE OEM 65-73 911 Engine oil thermostat
Porsche OEM Part #150255239721
Manufacturer;
Behr No. X1.215.83000 – 83°C/181°F, Porsche 911, 2.2 Liter
Put this in you alternate parts listing!
Manufacturer;
