Brake fluid indicator light is on...but fluid is topped off!
Posted: Thu Jan 14, 2010 11:25 am
by texas pinzgauer
We just bled the brake system and topped of the two brake fluid reservoirs under the dash but the indicator light stays on or flickers under braking and acceleration (can you really call it acceleration in a 712? :wink:).
The brakes work fine. Is the reservoir not quite full? What am I missing?
Posted: Thu Jan 14, 2010 1:17 pm
by chacaocop1
One posibility: You need to push the brake handle down a lot. It used to happen to me.
Another posibility: There is an electrical switch for the emergency brake connector underneath the truck that when it gets salt or other conductor particules causing continuity will create what you are experiencing.
I know where you live and Salt shouldn't be an issue unless you went to Galveston and left the truck parked there for a week.
Posted: Sun Jan 17, 2010 8:50 pm
by texas pinzgauer
Thanks Carlos, I'll check both of them!
David
