How to build a (relatively) cheap intercom system
Posted: Thu Mar 18, 2010 11:00 pm
I've taken 4x4Pinz's idea of an intercom and adapted common e-bay (read: inexpensive!) components to work very well in a Pinz 712 for 8 people. If anyone is interested, here's what I've discovered:
portable units (battery driven, or plug in to 24 volt) are available widely on e-bay or Craig's list. Most units are for 2, some for 4 but get very expensive for 6 or more people.
The Sigtronics SP0-42 or Flightcom SXII are commonly found and work fine. Picked one up a SPO-42 for $36.00 on Craigs list. Runs 70 hours on 2- 9 volt batteries. A Flightcom SX II with expansion module runs about the same price, same features. Got that one for $40.00. Each one has room for 2 headsets on the main box and 2 on the expansion module= 4 total, but I needed 5 or someone was going to be left out.
I mounted the SXII behind the passenger seat, and it's expansion module about half way down the rear side tucked up against the side wall behind the folding seats (hid it all behind the e-trak).
Did the same with the Sigtronics on the other side behind the driver. You can cut off the extra cables which were intended to connect the units to the aircraft radios, unless you need them. I rolled mine up with a zip tie and saved them for potential resale value later.
The 2 independent systems are then connected together with two mini plug stereo plugs on a 6 foot leads (Radio Shack- $7.00/ea) and attached the line out jack from the SX II to the line in plug on the Sigtronics and vise versa. All wires hide nicely along the cab bulkhead. Now I have 8 live outlets (driver/front passenger and 6 in the back) which can talk to each other when both systems are turned on, no shouting. Best part, I can flip a switch and turn off the wife if necessary.
I can also plug an MP3 or cell phone into the system. It's portable, not hard wired and hidden. Running on the highway is quiet, we speak in normal volume and hear tunes as the same time. I won't comment on the legality of the headsets on the road.
Used headsets are available on e-bay for $25+ a piece, but found better prices on local Craigs list. Many flight schools are dumping lots of units right now.
I know this is not for every one, but took me a few trial and error's matching parts before I came up with the above.
My passengers get quite a kick out of this "feature" in the Pinzgauer on our way to the local micro-brewery!
Ed
Ed
