712 AMB-S Corrosion on Drivers Compartment
Posted: Wed Apr 21, 2010 1:37 pm
by randwolfe
I am purchasing my 712 AMB-S next month and looked at it last week. I noticed corrosion on it and two others in the same location.
On the LHS, behind the driver, forward of the rear partition, at the joint between the outer wall and the floor (spot welded I suspect), just below the heater blanking plate, there is rust/flaking which progresses to the inside of the outer wall. Has anyone else seen this, and how did you treat it?
