Worrying clunk from steering box
spandit
Post by spandit »
My steering box, which is leaking slightly, had a lot of play which I've adjusted out. However, I noticed that there is a loud "click" when I turn the wheel, which I think it coming from the steering box. The adjustment also seems to be at the end of its travel. Can the grub screw be replaced with a socket ended one as trying to turn a flat blade screwdriver in that confined space is a little difficult?
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Twin Pinzies
Post by Twin Pinzies »
So is it a "click" or a "clunk?" I solved my leak and clunk problem before by rebuilding the steering gear box. Kits are available and it's pretty straight forward if you don't replace the pressed-in brass bushings.
I actually had a broken steering shaft!
spandit
Post by spandit »
It's a loud "click" - the steering play adjuster is more or less at the end of travel. Where can I get kits from? Should probably top up the oil in it anyway
Robin
Pinzgauer 710K
MegaJolt ignition
I think this is the kit referred to:
http://www.pinzgauer.com/showdetails.ph ... no=SAV3965
Sorry, missed the h when I cut and pasted the link :oops:
Pinzgauer Pete
Post by Pinzgauer Pete »
Paul the link you supplied is broken!
710M
try
Pauls link is missing an"h" :roll: opps
Ed
Twin Pinzies
Have you checked the stiffener arm that's attached to the steering gear box? It's the short rod under the diamond plate floorboard.
This has solved a steering clunk for me before... they do loosen up!
