Where is park brake switch?
Posted: Mon Jun 14, 2010 1:42 pm
by spandit
My parkbrake/handbrake light doesn't come on when I park the Pinz - I've tested the bulb - where is the actual switch so I can check from there?
Where is my parkbrake switch
Posted: Mon Jun 14, 2010 4:13 pm
by pinzmeister-uk
The parking brake switch is under the left rear corner of the truck and is operated by the swinging arm. Just follow the hand bake cable back and you'll find it.
Posted: Fri Jun 18, 2010 5:16 pm
by spandit
Thanks, Nigel, that would explain why I couldn't find it under the dash! Electrics do need a bit of a sortout, good job I've got a mass of heatshrink and twinwall cable in stock!
Re: Where is park brake switch?
Posted: Tue May 08, 2012 10:34 am
by berger
Is there is a non-steyr part for the hand brake switch at the rear? I believe mine is shot.
Posted: Tue May 08, 2012 10:52 am
by 4x4Pinz
Posted: Tue May 08, 2012 11:48 am
by berger
4x4Pinz wrote:The original is available at SAV
http://www.pinzgauer.com/showdetails.ph ... 111850350/
Thanks! I found it after I posted :oops: . I am hoping EI has one because I want to order the ignition conversion, sans petronix.
