Pulled gearbox, questions on evidence of leak and seals
Posted: Mon Jul 05, 2010 8:04 pm
Thanks for everyone's help in removing my gearbox from the 710. Its out and I'm studying it for signs of which seals need replacing.
Question 1: I noticed thick black oil accumulation within the bell that surrounds the clutch. I'm wondering how can I determine if its a leak of the rear main seal of the engine (behind the clutch) OR the front seal of the gearbox (behind the clutch engagement fork)?
Question 2: Is it possible a leak could come from some other point and leak into the bell? I noticed it is wet with oil at the base of the fuel pump, but i wouldnt think its enough to drench the inside of the bell, plus leave quarter size spills on the ground. How could i tell if its engine oil vs gear oil vs brake fluid?
Question 3: I noticed gear oil leaking from the rear of the gearbox, where i disconnected the drive shaft. I need to replace that seal. Would someone be so kind to tell me the part numbers needed for new gearbox gaskets? I have the diagram but im afraid I am missing something. The diagram just does not look like the gear box.
Question 4: As i rotated the gearbox, gear oil came out of a small nipple at the very top of the case, next to the box that you connect the shift selection arm to. As a matter of fact, its 2 inches forward of that portion of the case. It had a rubber cap on it which i did not remove. Is this something that I should just leave as is?
Question 5: In order to replace the two main seals at each end of the gear box, will I need to replace other gaskets to get to it? If so, which so I can order everything at one time.
I really appreciate your help here.
-Will
-Will
