What's the oil temperature supposed to be?
Posted: Tue Aug 03, 2010 12:27 pm
What is the "normal" oil temperature supposed to be. I did a search and found two pertinent threads.
Last week when the guage would climb to 230F I freaked out. But now I'm reading 230 might not be bad?
Last night I put the NAPA 7405 fan belt on and today I idled the 712 for probably 20 minutes and then drove it back and forth in front of the house for another 20 minutes or so. I never got above probably 25 mph and the temp guage stayed at 190F. Is that the "new" normal?
What is a proper range on oil temps?
Andy
What's the real scoop.
http://real4x4forums.com/PinzgauerBBS/v ... emperature
find that the oil temp is not a problem, mine rarely reaches 160 F.
Long highway runs on a hot day can get it up to 190 F.
Around town on a 110 F. day gets me 150-160F.
I insulated my lower crankcase and oil pan just to get the temps up to these numbers (was 120-130 max before).
When it is cool (below 50 F.) I need to block off the air intake tunnel to get the engine to warm up.
If your engine is running hot you might check for a dirty oil cooler and check for debris in your cylinder fins.
As you can see the opinions bounce around quite a range. My 712 would normally sit at @ 150F and in winter probably 120 Fhttp://real4x4forums.com/PinzgauerBBS/v ... emperature
Engines really like the oil to be warm, at least 180 F.
suspect the 230 figure is a result of the engine attaining stabized temperatures other comparisons are just that comparisons given a differing set of operating conditions
Regular oil is fine to 300 degrees, synthetic to 450 or so. Who cares about 230? Water starts to boil out at 212 so you want it at least that hot if possible. Remember everyone who bitches about the condensation under that oil cap? A thinner oil would most likely run cooler but it doesn't make a bit of difference to me.
Andy
