Is portal gasket change doable for novice?
Posted: Mon Sep 13, 2010 1:05 pm
by ziegler
Got a bad leak on the inside of the rim (passenger front), assuming it's the portal gasket. If so, is this an easy fix? Any imput apreciated. Thank you.
Posted: Mon Sep 13, 2010 2:40 pm
by audiocontr
Try carefully tightening the bolts on the plate around the knuckle. just snug em up. May help
Posted: Mon Sep 13, 2010 6:39 pm
by Erik712m
More than likely it's the hub seal. If you haven't done it. It isn't all that easy read the manual if it looks easy it will be.
