Clearance for 710K Tail Cone Removal
Posted: Sun Sep 26, 2010 8:24 am
I understand that in order to remove the tail cone, I have to lift the body away from the drive train to provide clearance.
I have read the procedure in the repair manual (in the brakes section) and the more detailed instructions written by Russell McIntire. They both say remove the tail cone bolt then loosen the rear cross member bolts by 5 turns.
Now the bit I don't undersatand. The manual says "If necessary, press down axle housing vigorously with an appropriate pipe". Russell says "Place a jack under the rear body out of the way of the work area to provide some support for the rear of the vehicle".
I can't get a picture of what's going to happen when I loosen the cross member bolts. Will the drive train drop as the body is held up by the suspension? Do I need the jack to lift the body after loosening the bolts? Most importantly, as a novice should I even attempt it?
