Drag link replacement
Posted: Fri Oct 15, 2010 2:36 pm
I had a bad drag link in my Haflinger, here's how I replaced it. First, order the replacement drag link. I bought a '74 Mercedes 240D tie rod assembly, here is the link-http://www.autopartswarehouse.com/sku/M ... 6+Steering
You will have to shorten the adjusting sleeve by 2.25" and tap the end with a 14 X 1.5 tap.
Here is the old drag link. I used a pickle fork to remove it.
This is the old link next to the new one. The ends are exactly the same. If you want to replace all tie rod ends at the same time order 3 assemblies. The adjusting sleeves are too short for the tie rods, but ordering the assembly is cheaper than ordering 2 ends.
New link installed. There's zero play in the steering now! Total cost was about $60, I bought the tap at NAPA. Note the oversize inner tie rod end. This was installed before I found out that the 240D assembly had the right part. I plan on changing this soon, and you benefit from my mistake!
