Removing muffler
Posted: Sat Nov 06, 2010 12:07 pm
Have had some conflicting reports on removing the muffler. I'm told that if I remove the 2 bolts on the rear mounting bracket, I can pull the whole thing out from the heat exchanger (if it's supported). Undoing/cutting the 6 flange bolts isn't an option
Nigel mentioned a support bracket above the heat exchanger as he says the sleeve couplings can be difficult (and he should know as I guess he's done a few) but mentioned it's difficult to access
