Clutch push rod
Posted: Mon Nov 08, 2010 5:53 pm
by Buzz
Working on a clutch problem. When I pulled the inspection cover over the top of the fork, I found the ball of the fork has been hitting the inside of the cover. It has been hitting long enough and hard enough to put a divot in the inside of the metal! The clutch was previously replaced and the plate resurfaced. Do I need to adjust something? Different push rod length?
BTW, I was chasing what turned out to be a leaking slave. If I need a new rod, I would like to order it at the same time as the rebuild kit. Thanks, Buzz
