Float level question
Posted: Sun Nov 14, 2010 11:38 pm
by og
Manual states that float level should be 16.5mm from the top of the carb body. How far from that value is still considered OK, in a sense that repair can wait. How does the performance of the carb vary (from a driving perspective) when level is 16.5mm and say 14mm or 12mm?
OG
Posted: Mon Nov 15, 2010 1:41 pm
If float level is low, you should first check fuel pump output(volume).
However if fuel supply is sufficient, you may need to check the float and float valve shim.
Poor accelleration / stumbling / running dry(big power loss) at highway speeds are symptoms of low float level/ poor fuel flow.
Posted: Mon Nov 15, 2010 6:31 pm
by og
Thank you Jim! My level is actually high when measured from ground or "low" if measured from the top of the carb bowl. I measure about 13mm instead of 16.5mm. So I am guessing there is more fuel in the carb then it should be. Would increased consumption be one of consequences?
Posted: Mon Nov 15, 2010 7:39 pm
I measure about 13mm...Would increased consumption be one of consequences?
I'll try to beat Jim L. to the punch and say, yes -- and likely your needle valves need replacing. This is exactly what he told me about mine!
712W with EFI and 710M with Jim L's carb repairs (runs great!)
Posted: Mon Nov 15, 2010 7:50 pm
by og
I was figuring 12 MPG was a bit steep for a 710M with rebuilt carb bases, Pertronix, proper timing and properly adjusted and balanced carbs.
Posted: Mon Nov 22, 2010 12:54 am
by og
For what is worth, I dug up some Pinzgauer documentation and found that carb float tolerance is +/-1mm.
