Oil Pressure Light
cctjoey
Oil Pressure Light
Post by cctjoey »
Hey guys, after the engine warms up for a while, the oil pressure light flickers lightly at times, brighter at others...sometimes not at all.
Idle-brighter
Running-flicker
Accelerating-off
Any ideas???
There is plenty of oil...
The first thing I would check would be to clean the terminal and make sure it's tight on the oil pressure sender. It may be loose which would give you the symptoms you're seeing.
Paul C
pinzdriver
oil light
Post by pinzdriver »
You may have a touchy press switch. :D
tony in az 73 pinz 6X6
pinzdoctor is the name,pinz repair is the game!
If in doubt, put a test guage on it before damage occours :wink:
