Servicing clutch release bearing
Posted: Tue Jan 11, 2011 3:19 pm
by spandit
Seeing as the release bearings are Pinz-specific and thus ****ing expensive, I'm inclined to re-use mine as it's turning freely and seems like it's in reasonable nick. However, it's got a fair amount of crud on it so I'd like to give it a good clean - thinking about soaking in kerosene and then regreasing (will normal UJ-style grease be appropriate?)
Posted: Tue Jan 11, 2011 7:32 pm
by milesdzyn
I'm probably wrong, but I thought that was a sealed unit and not servicable.
Miles
Posted: Tue Jan 11, 2011 7:46 pm
by Erik712m
Miles, probably is but I have greased mine twice.
clutch lube
Posted: Tue Feb 08, 2011 9:07 pm
by Winter Beater
I also cleaned mine (no solvent) and packed new lube in as best as I could. Used Brake caliper grease for the temperature. If the part was $35 I'd change it, but for $200 I'll pull the tranny again when (if) the squealing starts.
Re: Servicing clutch release bearing
Posted: Fri Jun 24, 2011 2:11 pm
by cruzoropeza
This squealing noise you speak of is it a loud noise or low noise?
Posted: Tue Jun 28, 2011 1:53 am
by WdeLange
