Differential ?
Gear
Differential ?
Post by Gear »
Does the Pinzgauer Differential have just a fill and drain plug. Or is it similar to the Transmission that has the 3 plugs(fill, level, and drain). I have looked in several spots for this simple answer but am still coming up empty.
Justin Pitcairn
2013 Jeep Wrangler Rubicon w/
Ursa Minor J30 Camper
Instagram @pitcairnoverland
landy
Post by landy »
The front and rear diffs have three plugs: a drain plug on the bottom, and a filler plug and control plug on the right side. The top plug is where gear oil is added until it begins to run out the lower control plug.
Gear
Post by Gear »
Thanks Landy,
I will get out there tomorrow and try and locate the fill plug.
Justin Pitcairn
Gear
Post by Gear »
Differentials - Simple drain and fill. Took some photographs because I am a visual learner.
Supplies used. AutoZone for the Coastal Oil. Used a little Anti Seize on the treads of the plugs. Boxed end wrench is used as a cheater bar for the allen wrench. Hammer to tap the plug before loosening. 5 gallon bucket for the used oil.
Front Differential - Gear oil is being pushed up into the top fill plug. You can see the new oil coming out of the Control Plug. The bottom of the differential has the drain plug.
The Rear Differential - Upper left corner is the Fill Plug. New oil is draining out of the Control Plug. Just above the bucket is the Drain Plug.
Justin Pitcairn
differential
Thanks Justin
totaljoint
Post by totaljoint »
Were we supposed to anneal the copper washers with a propane torch before re-installing them (to soften them up)?
(a quick acid bath after annealing made mine shiny like new, got rid of the burned tar/oil residue.)
differential
I bought some at Napa and rotate them. The one I take off I put in the bottom of the oven and when baking or some other oven related activity is going on it anneals. They are then ready for the next use.
No stress, no strain.
chacaocop1
Post by chacaocop1 »
Nice pics. Thanks.
CHACAOCOP
COZY
Re: Differential ?
Post by COZY »
Good instruction with nice visualization. Thanks! :P
2004 Defender 110
1979 Pinzgauer 712M
