techniques for loosening that big giant cooling fan nut
indigoth
Post by indigoth »
so, my fan belt is pretty loose. I really should adjust it before it leaps off the pulley somewhere. that big nut is mondo tight. I had a 4 foot breaker bar on it and couldn't budge it. I had some trouble holding the pin wrench in place while i was fighting with it. I don't have an impact wrench, nor am I able to get one in the near future.
any tips/clever ideas?
Jim
Re: techniques for loosening that big giant cooling fan nut
Mine was also mondo tight...took two of us. One to hold the stock pin wrench (while on the driver side) I had to stand on it, and the other
to turn the nut with a breaker bar. My friend had a very interesting tool that went on the square end of the bar and multiplied
the force. I have not seen one before or since, been looking though.
I think this might be what you're looking for:
http://www.northerntool.com/shop/tools/ ... _200315001
I saw one used once and was very impressed but couldn't convince myself I'd use it often enough. Of course that hasn't stopped me before when buying tools :D
spandit
Post by spandit »
I've discovered that normal driving does the job. I hope none of the cars behind us on the M6 got hit by the bits
Waiting for a tow truck :(
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin,
Did your fan blow up? I'm assuming so, from your reference to "bits". Pretty dramatic when it happens.
I found a piece embedded in, and nearly through, my engine cover. I ended up pulling the top tin off the motor, and found parts jammed into the cooling fins.
I can't help remembering the incident every time I run an engine with the cover removed. :!: A blast shield would be a wise idea for such an application.
spandit
Post by spandit »
No, fan is OK. It's the nut, pulley half & spacers I've lost. Writing this from the passenger seat if an AA flatbed
Robin
Pinzgauer 710K
MegaJolt ignition
