Gear Whine
Posted: Thu Mar 17, 2011 10:04 pm
by matthewc66
My mechanic in San Diego has been doing some work on my Pinz and he says he is concerned with gears 4 and 5.
He says in his opinion there is a lot of whining from the gears.
I told him they were straight cut gears and they have done that since I bought the truck.
Since I have never driven or ridden in a another Pinz I thought I would ask the group if this is normal.
it has always sounded the same to me so I never worried.
Also, if I need a tranny rebuild is there a way to put in a higher 5th gear so it isn't always riding in the higher RPM's when I am on the highway?
Thanks in advance for the help.
Matt
Re: Gear Whine
Posted: Thu Mar 17, 2011 11:47 pm
by Ditchdigger
WHAT? I CAN"T HERE YOU OVER THE GEAR WHINE! :mrgreen: Pretty much the conversation in my truck. Check your u-joints. I had one going out and changing it made a difference.
Re: Gear Whine
Posted: Fri Mar 18, 2011 12:01 am
Fifth gear in the stock tranny is straight through (1:1), so it cannot be changed. Turbo Diesels have an overdrive tranny but it loses the low gear, and the gears are slightly further spread apart. Many who have installed them have gone back to stock.
I think most owners would agree that the 12% increase in the 710 transfer case gives enough speed, but the lower 712 transfer case does make it hard on the highway. Some have even put the 710 case in a 712.
Re: Gear Whine
Posted: Tue Mar 22, 2011 10:26 am
by Twin Pinzies
In my experience, people are just not used to hearing all the gear noise coming from a Pinzgauers drivetrain. Most just assume that there are bad bearings!
I doubt that yours is having problems...
Re: Gear Whine
Posted: Tue Mar 22, 2011 10:57 am
by matthewc66
Thanks. It has always sounded the same since I got it.
I will get a ride in a local Pinz to see if there is any difference in sound.
Matt
Re: Gear Whine
Posted: Sat Mar 26, 2011 12:08 pm
by pinzwheeling
If you'd like, you could bring it up to Ramona to my shop and I could take a listen for you. Pinzgauers are loud at speed, many of us use earplugs on longer rides
Re: Gear Whine
Posted: Sun Mar 27, 2011 2:43 am
by matthewc66
That is a generous offer and I thank you for it..
My challenge is my gears have always whined but my mechanic seems to insinuate he thinks they are going to explode one day.
I don't want to to take it on any extended trips until I can tell whether this is a serious problem or just much ado about nothing.
Justin lives close by to me. We are going to try and hook up to see if our trucks sound the same. If they do then I will probably just keep driving. it..
I will keep everyone informed..
Matt
Re: Gear Whine
Posted: Sun Apr 03, 2011 11:02 pm
by westernair
Well Matt did you guys hook up this weekend? Mine is load too and I wonder the same
Re: Gear Whine
Posted: Mon Apr 04, 2011 10:13 am
by matthewc66
We didn't.
I had to put my Pinz back into storage for a few weeks and rotate some of the vehicles around.
I will get it back in a few weeks and then try and touch base with him again..
