Turn Signal lever is Stuck?
Posted: Thu Mar 24, 2011 8:49 pm
by Gear
Hello Everyone,
I am having trouble getting the turn signal lever to go up and down. It seems to be binding. For the most part it is left turn(pushing down) when it binds. I took it apart but did not see anything out of the ordinary. Any thoughts!
Re: Turn Signal lever is Stuck?
Posted: Thu Mar 24, 2011 9:11 pm
by Winter Beater
Mine became sticky and difficult too. Sprayed it with Elec contact cleaner and then added a little teflon lube to the moving parts. If anything it is a little too easy to kick off to the neutral position, but I no longer fear breaking the lever every time I change lanes. (yes despite living in Denver I use my signal lights)
Posted: Fri Mar 25, 2011 6:45 pm
by Gear
Thank You Winter Beater. Took it apart again and cleaned it up. Added a little lubricant and it works great now. Thanks
