CB console
Posted: Mon Jul 11, 2011 9:33 am
by StuartL
Simple CB console manufactured out of 6mm ply. Has 24v-12v 30A DC-DC converter, Kernow 2100GTL 80-channel CB, two 12v cigarette lighter sockets and two USB ports. The cigarette lighter sockets and USB ports are hidden in the cubby-hole above the CB which has velcro to hold phones etc out of the way. The light in the first photo is a cheapo map reading light bought from Maplin for an extortionate £4 (about $6). It serves as both an interior light in the dark and a light for the CB display which isn't backlit. The console is held at the front by the visor mounting bolts and at the rear by a plate under the antenna mount with a long bolt. You can see the head of the bolt in the photos.
The antenna mount is a 141mm diameter stainless steel disc with five holes cut in it and the 3/8" antenna mount bolted through the middle.
Little bit of wiring to tidy up (you can see the 24v power loose in the second console photo) and the edges could do with sanding and repainting. Otherwise I'm very pleased with it.
Re: CB console
Posted: Mon Jul 11, 2011 9:36 am
by spandit
Looks good - can you hear the CB when the engine's running, though? My installation won't be as neat as that...
Re: CB console
Posted: Mon Jul 11, 2011 9:51 am
by audiocontr
Any idea what that single wingnut is for? I have one as well at that exact location.
I mounted my CB facing forward off of that bolt. Puts the speaker right above my ear and keeps it out of site. I like the idea for the CB ant through the center plate! I wonder if it would leak though.
Re: CB console
Posted: Mon Jul 11, 2011 9:54 am
by StuartL
spandit wrote:Looks good - can you hear the CB when the engine's running, though? My installation won't be as neat as that...
Yes, the photos aren't at the right angle to see it but there's four large-ish holes under the CB to allow the sound free access to the air-space in the cab. I haven't actually had chance to test it while motoring yet but certainly when the volume is up and I turn the squelch off it's deafeningly loud!
audiocontr wrote:Any idea what that single wingnut is for? I have one as well at that exact location.
That wingnut appears to be a locking nut, not sure why it's there. Maybe someone else did a CB installation the same way you did?
The antenna mount seems pretty good, there's a rubber disc under the antenna to act as an insulator and seal so I doubt it would leak much if at all. It's also done up as tight as I dared without risking the plastic/rubber integrity.
Re: CB console
Posted: Mon Jul 11, 2011 10:04 am
by audiocontr
Does that rubber seal prevent the ant from grounding though?
Re: CB console
Posted: Mon Jul 11, 2011 10:09 am
by StuartL
No, the stud mount I've used has the 'live' antenna connection as a 3/8" single pole stud connection. That connection is isolated from the chassis using a plastic shield and the aforementioned rubber insulator. The chassis ground (and my ground plane) is achieved with the bottom half of the stud mount which electrically connects the RG58 shield to the stainless plate. There's no ground connection to the antenna itself, it's just conveniently shaped and tuned springy piece of wire.
Re: CB console
Posted: Mon Jul 11, 2011 10:12 am
by audiocontr
yup, understood
Re: CB console
Posted: Mon Jul 11, 2011 1:17 pm
by 4x4Pinz
If you do have trouble hearing the CB a simple external CB speaker works great mounted just below the head bump guard.
Re: CB console
Posted: Tue Jul 12, 2011 2:42 pm
by cruzoropeza
Nice!
