charged batteries out of truck, now no start???
Posted: Tue Aug 30, 2011 3:29 pm
by stiffler4444
I have a stupid question, and welcome a stupid answer if it's that simple.....
I removed my batteries from the truck to give them a good deep charge, as it had sat for a couple weeks. Ran perfect, no battery issues prior. Once placed back in the truck, I have dash lights, very weak, and only the occassional click of the starter solenoid. Not even an attempt to start. Checked the batteries, still fully charged.
Something common or simple I've done here? The batteries are wired positive - negative - positive - negative........as they came out......
Re: charged batteries out of truck, now no start???
Posted: Tue Aug 30, 2011 4:13 pm
by StuartL
You haven't wired them backwards, have you?
Or is there a bad connection, maybe?
Posted: Tue Aug 30, 2011 4:17 pm
by stiffler4444
Hi there,
All visible connections are good, and i wired them with the front battery positive to the truck, negative to the positive of the back battery and negative to the truck. By front battery I mean closest to the driver....
tx Dave
Posted: Tue Aug 30, 2011 4:34 pm
Spray some WD40 into the ground switch and actuate it a few times to clean the contact and double check battery cables/connections for good contact.
The short cable can go bad(high resistance) if it is too corroded.
Posted: Wed Aug 31, 2011 9:09 am
by stiffler4444
Well, I have lubricated and actuated the ground switch a few times, cleaned all of my contacts and inspected the wires for any breaches....nothing. Now I don't even hear the solenoid click.
Guess I'm gonna be going on a "hunt" very soon for whatever has changed.......just amazed this can all take place by simply removing the batteries!!!!!!
Posted: Wed Aug 31, 2011 9:22 am
by StuartL
Have you checked the factory fitted immobiliser beeps when you disarm it with the remote?
Posted: Wed Aug 31, 2011 10:01 am
by audiocontr
Check battery voltage with a multimeter. Then check voltage somewhere under the dash. I'm betting a cable is rotted through which broke when you reattached.
Posted: Wed Aug 31, 2011 11:08 am
by stiffler4444
Sounds good, I'll try this tomorrow (working late tonight
Posted: Wed Aug 31, 2011 11:09 am
by stiffler4444
StuartL wrote:Have you checked the factory fitted immobiliser beeps when you disarm it with the remote?
Lol...I'll check this as a last resort
Posted: Mon Sep 12, 2011 8:36 am
by stiffler4444
Finally got around to checking more in depth, and was happy to find the answer in short order. My batteries show more than acceptable voltage on the meter when charged, but after attempts to start, one was droping below 10.5v. I put it on the charger and it immediately showed full charge. Tried it in my dodge and didn't even get a dash light. Sounds shorted or something. New battery and all will be well.
thanks for the replies, always helps to get other's input.
Dave
Posted: Mon Sep 12, 2011 11:41 am
by audiocontr
FYI, I was the gent who stopped by and said hello a few weeks back.
Posted: Mon Sep 12, 2011 11:42 am
by audiocontr
Are you tapping one of the batteries as a 12v source?
Posted: Mon Sep 12, 2011 12:04 pm
by stiffler4444
No, everything is bone stock.....these are the units I recieved with my truck and the dead one was the "rear" battery location....
Posted: Mon Sep 12, 2011 12:06 pm
by stiffler4444
audiocontr wrote:FYI, I was the gent who stopped by and said hello a few weeks back.
I thought so, wish I would have tried the truck while you were standing in the driveway, I think it was the next day or so it wouldn't start! I beleive you have a bit more electrical savy than I..........
Posted: Tue Sep 13, 2011 10:58 am
by audiocontr
Sounds to me like the previous owner was tapping the rear for 12v. pretty common.
I swapped mine out as well but saved that battery as a spare in the rear of my pickup. Comes in handy for jump starting and powering the winch/air compressor in a bind.
