Distributor ignition sequence 1,2,4,3 (but which is which?!)
Posted: Sat Oct 15, 2011 1:06 am
1974 710M-
Sorry to be the rookie... I don't do much maintenance myself, but decided to clean and check spark plug gaps. I went to put the wires back on from the distributor, connecting the cables to the spark plugs/cylinders, and realized I didn't mark them to know which cable goes to which cylinder. (stupid me)
Looking at the distributor with the cable leading in at the bottom/the coil to distributor... looking directly down from above on the distributor and the using the cable coil to distributor as the 12'oclock position -
in the 9 to 12'oclock position that is cylinder 1,
12 to 3'oclock position goes to cylinder 2,
3 to 6'oclock position goes to cylinder 3,
and 6 to 9'oclock position goes to cylinder 4,
(in a clockwise pattern)
Correct?
My book is confusing me because it says "1,2,4,3."
(but in which direction? Is that looking at the distributor from the top and reading it like a book,
top row left-1 to right-2, then second row left-4 to right-3?)
Thanks for any help
Correct?
Thanks for any help
