Steering support loose
Posted: Mon Oct 31, 2011 10:48 am
by NoahDL88
Anybody have any tips or tricks about tightening the inboard end of the steering support bracket on the inside of the cabin, I can't get a wrench on the bottom side and the noise it makes is a little disconcerting.
I think cutting it and putting a new bolt in is a no go as I'll just have the bottom half stuck in instead of the whole thing.
Re: Steering support loose
Posted: Mon Oct 31, 2011 7:47 pm
by Twin Pinzies
You can't get a wrench on it? Did you remove the floor pan?
Posted: Mon Oct 31, 2011 11:15 pm
by NoahDL88
I removed the floor pan but there isn't much room at all, the piece it's bolted through doesn't leave enough room for even a stubby wrench.
Posted: Tue Nov 01, 2011 3:07 am
by StuartL
I haven't looked at this bit but I found with the handbrake housing a ring spanner was the only tool I could get onto certain nuts.
