Brake Master Cylinder C306
Posted: Tue Dec 13, 2011 3:13 pm
by 959gav
I need to replace or repair the Brake Master Cylinder on my C306, But I'm having a spot of bother finding parts or kits!
Like with the wheel cylinder is there any Rover parts that I can use? or are there and repair kits that don't take the mick price wise?
Gav
Re: Brake Master Cylinder C306
Posted: Wed Dec 14, 2011 1:40 am
by wrangler_tj
First what's the problem with the brake master cylinder?
Alos take it out of your Volvo and measure it up. Lenght and inner diameter.
Probaly you can take one of a Volvo 164 with hydrolic brake assist.
If you have it out of your Volvo let me know the brand and number on it,
than I can look it up for you and tell you how to find one.
Posted: Wed Dec 14, 2011 8:32 am
by 959gav
Thanks for the reply
Well all the Wheel Cylinder where basically seized, so when when looking at the Master Cylinder I could see it has had a fluid weak. So now I'd like to at least replace the seals.
I'll take it off and come back with the relevant sizes etc
Posted: Thu Dec 15, 2011 7:04 am
by 959gav
The Master Cylinder is a
FAG 55204 34 then 28
Bore is 31mm
Length 217mm
And it's going to need to be replaced
Posted: Thu Dec 15, 2011 8:16 am
by Doccers
959gav wrote:The Master Cylinder is a
Bore is 31mm
Length 217mm
http://tatanka.nu/50_Wheel_Brake.asp
Posted: Thu Dec 15, 2011 1:58 pm
by 959gav
Tatanka might be selling original parts, but there's no way I'm spending over £700 for a Master Cylinder!!
Posted: Sun Dec 18, 2011 11:18 pm
I hope you realize there are also 2 remote hydraulic brake assist cyinders on the boosters as it is a diagonaly split braking system.
They are not cheap. If you have brake fluid dissappearing, you will find it in the boosters. I pulled at least a liter out of the 1 bad booster I replaced on Greg's 303.
