Will These Tires Fit?
Posted: Mon Jan 02, 2012 5:24 pm
I'm wondering if these uniquely tall tires will fit a Pinz. My 710K sits pretty tall at 82 inches at the roofline, so no sagging springs, but what about turning/bump clearance? Here are the specs.
Technical Information from michelin site for new 255/100R16 XZL tyres:
Michelin reference 110650
Ply rating
Unique point 134/128 J
Nominal load per axle - single fitment (kg) 3400
Nominal load per axle - twinned fitment (kg) 6400
Nominal pressure in bars (single fitment) 4.50
Nominal pressure in bars (twinned fitment) 4.50
Nominal pressure in bars (unique point) 5.75
Wheel recommended 6.50H
ETRTO section (mm) 260
ETRTO diameter (mm) 936
Free section (mm) 255
Free diameter (mm) 923
Crushed section (mm) 286
Crushed radius (mm) 426
Rolling circumference (mm) 2798
Minimum distance between axle centres (mm) 288
Tread depth (mm) 16.5
Regrooving depth (mm)
Weight in kg 39.90
Tube
Flap
Sealing ring
Regulation 54 007700
ETRTO approved rims 6.50H
Ply rating
Weight in kg 39.90
Tube
Flap
Sealing ring
