White or red mark for timing?
Posted: Sat Jan 07, 2012 4:38 pm
by audiocontr
I was setting the timing on my newer tan pinz after a civilian conversion and noticed it has both a red and white mark. Which do i use? I could remove the cap and try to line the distributor up to #1 TDC if i get a few moments but i was hoping someone would know off hand.
Re: White or red mark for timing?
Posted: Sat Jan 07, 2012 5:38 pm
if i remember correctly only one notch is cut in the pulley, that would be tdc.
Posted: Sat Jan 07, 2012 10:09 pm
One might have been set to indicate before or after TDC to compensate for altitude.
Mine is set for above 5000 feet...different than when I lived at sea level. A timing light that is set
for 8 deg. was used to set the timing.
