Carb Balancing
Carb Balancing
Knowing that the Pinz has dual carbs, I am curious as to how the carbs are balanced? I did search, but I couldn't locate anything on technique or tools required. The reason I ask is, I used to use a TwinMax to balance my dual carb'ed Ural, but now I use a much cooler tool called the Harmonizer... 8)
Is it simply a mechanical linkage that needs adjustment, or is it a vacuum balance?
Re: Carb Balancing
Look at this from Expedition Imports http://www.expedition-imports.com/categ ... ning_info/
Re: Carb Balancing
edzz wrote:Look at this from Expedition Imports http://www.expedition-imports.com/categ ... ning_info/
Thanks Ed!
