Gearbox drop link
Posted: Fri Feb 03, 2012 11:52 pm
by evopinz
Has anyone replaced a gear change link (with a ball joint each end) which is attached to the gearbox.Do the ball joints just snap on? There is not much room under the Pinz. Do I have to pull things apart?
Is there a trick to it and does it require a bit of grease?
Thanks in advance
Re: Gearbox drop link
Posted: Sat Feb 04, 2012 8:52 am
by kpoling
Posted: Sat Feb 04, 2012 9:54 am
by crcpinz
It's an easier fix if you remove the pyramidal cover that is on the rear deck above the gearbox.
Posted: Sun Feb 12, 2012 4:37 pm
by evopinz
I successfully installed the new drop link on the weekend.With the pyramid cover removed it was a lot easier.I popped the top ball joint on with a 'G' clamp and then held the bottom of the link with a spanner on the lock nut to stop it turning while I poppped the bottom joint on the ball with a large screw driver by levering off the body of the truck.
Thanks to everyone on the forum for your guidance.
