Wheel drive tool press.
Posted: Sun Feb 05, 2012 8:06 pm
by 19D20
I want to fab one. Can anyone supply a blue print ?
Re: Wheel drive tool press.
Posted: Sun Feb 05, 2012 10:48 pm
I use a wedge(to hold the split open) and a porta power to remove the wheel drives.
Posted: Mon Feb 06, 2012 8:49 am
by czarthirteen
Jim LaGuardia wrote:I use a wedge(to hold the split open) and a porta power to remove the wheel drives.
Ditto......not a real Porta Power, but I've got a lot of hydraulic-over-electric rams of assorted sizes...I found one that fit the bill and it was easy-sleazy.
Going back on was another story......but I used my own brand of persuasion. A two-foot long section of a black walnut 8x8 and a 14-pound sledge did the trick.
Posted: Mon Feb 06, 2012 2:28 pm
Drives go on very easy if you install the wedge to the gap and then use a come a long to pull it back together(last 1/2")while keeping the alignment pin hole in position. Always avoid using hammers where finesse is needed.
Posted: Wed Feb 08, 2012 10:57 am
by 19D20
Thanks guys, I'm dreading tearing into it but the differential has been leaking badly for a long time.
