Side Vent...
Posted: Tue Feb 28, 2012 8:32 am
by berger
Hey Guys...
What is this exactly?
On the truck I am buying (pick it up tomorrow!!), this plate/vent cover is slightly damaged in the upper rear corner. What is it and is the cover easy to find/replace?
Re: Side Vent...
Posted: Tue Feb 28, 2012 8:45 am
by audiocontr
the K series have a heater in that location. The space serves as a vent for said heater. The M series have the panel you posted as there is no heater. Pretty easy to get though i would make something for the price.
Re: Side Vent...
Posted: Tue Feb 28, 2012 8:46 am
by audiocontr
i just love those side rails!
Re: Side Vent...
Posted: Tue Feb 28, 2012 8:52 am
by berger
audiocontr wrote:the K series have a heater in that location. The space serves as a vent for said heater. The M series have the panel you posted as there is no heater. Pretty easy to get though i would make something for the price.
The truck I bought/buying has the gas heater right behind the drivers seat...makes sense now.
Re: Side Vent...
Posted: Tue Feb 28, 2012 9:53 am
by kpoling
Available from SAV: http://www.pinzgauer.com/showdetails.ph ... 1740492/95
PINZGAUER Gasoline 710/712: Body
COVER PLATE LH SIDE BEHIND DOOR
Part No.: 7111740492/95
Group: 25-05-21 » Drawing
Price: 49.50 US$
Availability: IN STOCK
Condition: NEW
Re: Side Vent...
Posted: Tue Feb 28, 2012 10:23 am
by berger
kpoling wrote:Available from SAV: http://www.pinzgauer.com/showdetails.ph ... 1740492/95
Price: 49.50 US$
Condition: NEW
Thanks!
Re: Side Vent...
Posted: Tue Feb 28, 2012 10:53 am
by audiocontr
Well, hold up a sec... if the truck has a heater, it should have the vented version of that plate, unless its some sort of aftermarket install. Just make sure you get the right plate if you decide to replace it.
Re: Side Vent...
Posted: Tue Feb 28, 2012 11:16 am
by berger
audiocontr wrote:Well, hold up a sec... if the truck has a heater, it should have the vented version of that plate, unless its some sort of aftermarket install. Just make sure you get the right plate if you decide to replace it.
Gotcha...I cannot quite remember, and my pics don't quite capture it...
Re: Side Vent...
Posted: Tue Feb 28, 2012 1:37 pm
by waterdog
mine has the same plate sealed, and has the heater right behind, i did remove to check inside and there is a small fan, i dont know why the plate is sealed,.... :?:
Re: Side Vent...
Posted: Tue Feb 28, 2012 1:52 pm
by audiocontr
parts get swapped over 40 years :D
Re: Side Vent...
Posted: Tue Feb 28, 2012 4:46 pm
by totaljoint
I have a heater, my vent is a sealed cover.
It all depends on where your heater gets it's cold air from....outside (cover will be vented and the heater intake pipe will be just inside the vents) or re-circulated inside air (cover will be closed, intake pipe will be turned away from the plate).
With recirculated air, there is less chance of sucking in exhaust fumes when stopped, since it's on the same side of the truck as the stock exhaust. Of course, if it does suck in fumes anyway, you'll die faster.
Re: Side Vent...
Posted: Tue Feb 28, 2012 6:52 pm
by crcpinz
Watch out for that sucking, better to recirculate.
Re: Side Vent...
Posted: Wed Feb 29, 2012 10:05 am
by kpoling
My vent works & I open it when using the heater. The vent leaks cold air even when closed while driving my truck. Maybe that is why some are sealed up? :?:
