Body corrosion
Posted: Thu Jun 28, 2012 11:13 pm
Guys
I suppose it was time!
Instead of looking at rust patches previously repaired /patched by the Swiss mil on some rigs, we got busy with a die grinder and cut out the bed as it is formed over the chassis bed rails.
The real culprit is road water washed up by the rear road wheels which is forced between the rails and the bed sheething. A thick layer of underseal hides the damage going on until it blisters out in the bed.
Fortunately the rails are very thick and can stand years of surface corrosion .
On this 710m model/specimen we have decided to use angle stock to reinforce the rail and reform it to the bed where the rear seats are anchored.
If your truck is deteriorating in the bed it might be time to re-skin it before it really gets into the chassis rails. Basically not as daunting as you might think.
Dennis
Linden Engineering
Dennis
Linden Engineering
