Full hydraulic steering
Posted: Wed Jul 18, 2012 2:39 pm
by wrangler_tj
Does anyone has full hydraulic steering on his Volvo?
Not power steering with the electric power steering from Opel/Vauxhall,
I don't believe in this option.
I'am looking for it and has this kit in mind:
http://www.pscmotorsports.com/toyota-fu ... r-kit.html
I only need to mount a power pump on the engine and a overflow bottle.
I searching one from a Volvo 164 that will bolt directly on the B30 motor.
Re: Full hydraulic steering
Posted: Mon Aug 05, 2013 3:04 pm
by Selloutrr
Have you made any progress on the hydraolic steering?
Why is electronic steering not an option for you? I understand early designs gave limited driver response however with electronic steering now becoming the OEM choice for many manufactures. The driving experience has improved greatly.
One of the down sides of hydraolic steering and the main reason for the shift in production mentioned above is that the power pump on average sucks 1MPG from the fuel economy. (Ouch!)
Posted: Tue Aug 06, 2013 5:56 pm
by roobar_and_custard
Isn't full hydraulic steering illegal for road use? I thought the regulations required a mechanical connection, which doesn't exist in the hydraulic systems.
It's fine for competition trucks which are not road registered.
Ian
Posted: Wed Aug 07, 2013 11:11 pm
by Selloutrr
This should help answer that question. It's state by state.
http://www.liftlaws.com/is_full_hydro_s ... _legal.htm
Posted: Fri Dec 06, 2013 6:18 pm
by Montrealrr90
Posted: Fri Dec 06, 2013 6:20 pm
by Montrealrr90
Posted: Wed Mar 26, 2014 4:50 pm
by Montrealrr90
Here's my update on the steering for my portal boxes
I finally went with PSC has they were willing yo work with us. The problem is that there's only 4 inches from side to side and that most rams are 6 to 8 inches. PSC has put stoppers inside the ram at 4 inches. I will be getting the truck back soon and will post.
Posted: Tue Jul 15, 2014 7:15 am
by Montrealrr90
Posted: Wed Feb 10, 2016 9:23 pm
by ranicotra
Have you been satisfied with the performance of the PSC power steering now that you've had it on your vehicle for awhile ?
