Oil Cooler Removal
Posted: Fri Aug 24, 2012 12:56 pm
by PhilH
I am replacing the seals in my oil cooler this weekend. Before I make a big, big mess, do I have to drain any oil before I remove the cooler? Can I remove it with the oil filter still attached? Is the same true for the oil filler tube? Thanks.
Re: Oil Cooler Removal
Posted: Fri Aug 24, 2012 1:01 pm
by pinzinator
It's easier if you remove the filter and then the cooler. You don't have to drain anything, but you'll spill some oil, that's unavoidable. If you leave the filter on the clutch hose gets in the way.
Change the gasket on the fuel pump base at this time if needed, access is easy.
Posted: Fri Aug 24, 2012 1:52 pm
by PhilH
Thanks. I also have the gaskets for the fuel pump. Does it just lift up and out? Nothing will drop down will it?
Posted: Fri Aug 24, 2012 2:24 pm
by krick3tt
put a rag under the filter, slide it from the back and it may catch most if not all oil you will spill.
You can also loosen the filter a bit and put a baggie over it to catch the oil.
Posted: Fri Aug 24, 2012 3:05 pm
by michaelh712
After loosening slightly, Place a plastic bag over the filter and remove with no mess!
Posted: Fri Aug 24, 2012 3:26 pm
by krick3tt
What...what...I think there's an echo in here.
Posted: Fri Aug 24, 2012 5:12 pm
by pcolette
The oil filler tube does not have to be removed but the dipstick tube does.
Posted: Tue Aug 28, 2012 11:35 am
by PhilH
Thanks for the advice on the oil cooler seal replacement, fuel pump, and such. It was a pretty straightforward job. I am curious why there is no gasket between the cooler and the thermostat housing though. Should I have put some sealant on there just for good measure?
Posted: Tue Aug 28, 2012 11:44 am
by pinzinator
An o-ring is installed with the thermostat itself, but nothing goes between the thermostat housing and the oil cooler except the 2 round seals.
