Seat Belt Re-inforcements
Posted: Sun Sep 30, 2012 9:26 pm
by ExpeditionImports
Hi Guys,
Pictured is an additional option for seatbelt re-inforcements. Takes a little work but defintely adds rigidity to the A-track mounting.
Scott
Re: Seat Belt Re-inforcements
Posted: Mon Oct 01, 2012 3:11 am
by Tibbermore
Looks like a neat job. What size metal strap did you use for the reinforcing bars? Is the E-Trac welded to the bars or just bolted on? Is the bottom edge of the lower bar lined up with the base of the side rail; I saw some posts indicating it is better to keep the E-Trac up a little to allow the seats to clear when folding over - is this an issue? Thanks
Posted: Mon Oct 01, 2012 11:20 am
It's actually L-channel for rigidity. 1.5" x 1.5" Once the channel is welded to the rails we use a really high tech method to drill it every 6" for the M6 Nuts and Bolts to bolt the A track to the channel.
The bottom of the E-track is high enough up the rail to clear the folding seats with belts installed. (About 2".5")
Scott
Posted: Wed Oct 03, 2012 12:03 pm
by Roverchef
Too bad it's not the 4x4 mobile-workbench version...Great outta-box think'n Scott!
