Tool Box Organization
Posted: Thu Nov 08, 2012 7:23 pm
Thought I'd share something I found for the tool box.
The box on my Pinz is big enough, but has it's drawbacks. The tools just pile up in it, and it is open to water/humidity. The one item I need seems to be on the bottom and the pile of tools slide out when the door is open. Sliding cargo have even popped open
some oil bottles, and rattle on rough roads (and yes, I hear it over the engine). Canvas rolls are nice, but not big enough nor waterproof.
I consider the original tools something of value, and only keep in the truck those that are specific for use on the trail. For general use I've replaced the common hand tools with Harbor Freight metric wrenches and sockets. No big $ loss if I lose or lend those.
French medical boxes http://store.colemans.com/cart/french-m ... -2421.html ($19.95) are steel, waterproof and fit in the Pinz tool box like a glove. Most I've ordered are in great condition, (though a couple have had damaged gaskets- Coleman's has replaced those readily, and even 3/8" replacement gasket material can be found here http://www.mcmaster.com/#epdm-rubber-bu ... ts/=k2xc4u). The lid is attached and makes for a clean surface out of the dirt to put tools/washers/nuts, etc.....
I took the "California Closets" approach to organization and used these to load up my hand tools:
Use one for some original tools, and brake adjustment:
Another for sockets/screwdrivers/allen wrenches etc..
And another for oil/fluids/fan belt and used to have a fuel pump and filters in there too:
All together they leave me with room for the jack and longer items to hold it all in place:
Hope this helps!
Ed
Hope this helps!
Ed
