Disconnecting batteries
Posted: Fri Nov 09, 2012 12:06 pm
Could someone tell me what the proper sequence is when removing the cables from the batteries? On the Iltis, I removed the kill switch, disconnected the negative at the 12v side (driver's side battery), then disconnected the 24v from the second battery (passenger side). I then disconnected the cross connect cable between the batteries first at the positive terminal of the passenger side. Reinstall was in the reverse order.
I don't want to fry anything...
Thanks!
Thanks!
