Leak at Cover on Transfer Case
Posted: Mon Nov 12, 2012 9:20 am
by undysworld
I'm looking at a friend's 710, which seems to have gear lube leaking from the passenger side of the transfer case, from under the little cover shown as part 58 here: http://www.pinzgauer.com/parts.php?cat= ... view=02-50
It also shows a gasket, so I assume that could be my problem. I've looked in the manuals, and I've not seen anything to indicate that I shouldn't remove it. Is this cover truly just a cover I can unbolt to replace the gasket?
Re: Leak at Cover on Transfer Case
Posted: Mon Nov 12, 2012 3:39 pm
by edzz
As I understand the manual on page 18 of the auxiliary gear box section this is an access cover to provide access to adjust the selector fork see fig. 46.
I can see nothing that would prevent me from removing this cover to replace the gasket.
I would expect to lose some gear lube in the process.
:shock: Note: being as I have never had need to remove this cover my opinion is strictly based on what I see in the repair manual.
Posted: Mon Nov 12, 2012 7:15 pm
by undysworld
Thanks edzz, that was my guess there too. No worries about fluid, as a drain & fill was planned anyway.
Posted: Tue Nov 13, 2012 7:31 pm
by Roverchef
When I first got mine it was leaking from there. I pulled it off and made a new gasket from a box of corn flakes and it has never leaked again. Simple R&R and refill the box.
