Spring ???'s
Posted: Sat Dec 22, 2012 6:26 pm
by Roverchef
What are K and M front spring lengths when new? I searched the forum but couldn't find the answer. If you were to replace the front saggy springs on a 710K...which ones would you use...diesel ones? I have an idea for a cheaper spring but I would like to know the spring rate/length of the stock one's if anyone knows it before I go and "Franken-pinzy" the front end suspension.
Re: Spring ???'s
Posted: Sat Dec 22, 2012 7:06 pm
by 4x4Pinz
Mark had six sets made from the company in Kansas. I am not aware of any of them still in trucks. The original springs have a variable spring rate which is hard to get made. The rod diameter of the spring is smaller at the ends. The spring rates for the three stock springs are in the manuals. Stan and Mark came up with a design to help with the ride height. The book also list different sizes of pinz that the spring cup sets on to make the body adjustments.
I will get some pics up tomorrow of the difference the mod made to my truck.
Re: Spring ???'s
Posted: Sun Dec 23, 2012 9:23 am
by Roverchef
Thank you for the info. I know the springs are "progressive" which would make them variable and not linear type. I may go on and try my little experiment and see how they work hence I have @ least twenty different sets laying around the shop that seem to be the same LxWxH as the ones that came off the rig. Thanks again in advance for any help.
Re: Spring ???'s
Posted: Sun Dec 23, 2012 10:52 am
by 4x4Pinz
while Mark was working on getting the springs made I hit up a local suspension company that I worked on many projects with to help wiht the springs. I gave them an example and the spring rates listed in the manuals. They could not find any that would just drop in. If you are able to find an off the shelf spring I am sure some would be very interested.
Re: Spring ???'s
Posted: Sun Dec 23, 2012 1:38 pm
by 4x4Pinz
Front View with sagging springs and after with Mark/Stan's modification.
Re: Spring ???'s
Posted: Sun Dec 23, 2012 5:26 pm
by Roverchef
I asume the 1st photo is w/ the new springs and the lower 2nd photo is before the change...?
Re: Spring ???'s
Posted: Sun Dec 23, 2012 6:13 pm
by 4x4Pinz
Yep, does not show up well on the camera photo with the shadows. I will try to get a better one in the next day or two once things calm down a bit. It actually raised my front bumper height 3.5".
Re: Spring ???'s
Posted: Mon Dec 24, 2012 6:49 am
by waterdog
sooooo. what is the mod you did on your truck??? can we see pics :?: :?: :|
Re: Spring ???'s
Posted: Mon Dec 24, 2012 7:32 am
by Roverchef
I am in the process of a front winch bumper and by adding that weight to the front end will definitely finish off the already saggy springs hence they are only a "Beavers Fart" (water tight) from riding on the bump stops. I'll post pics when it's done and if the spring replacement works I'll definitely let everyone know what I used so you too can level-out your Pinzy!
Re: Spring ???'s
Posted: Mon Dec 24, 2012 9:24 am
I added a winch and tub steel bumper and dropped the front about 3/4 inch. Not enough to worry about as I still get over the things on the trail.
