VDO Electronic Speedomter Wiring
Posted: Sat Jan 05, 2013 6:24 pm
by landy
I bought a VDO speedo to replace the original one which stopped working. The gauge wiring diagram shows a wire from the light switch to the gauge lights. I haven't yet looked at the book of the original switch so are there terminals on the back that I can connect the wire for the gauge lights to, or do I have to splice a wire? If so, is there a recommended wire or location?
The diagram shows a wire from the fuse block to the gauge for a power source. Is there a recommended splice location or some other location that would be better?
Thanks!
Re: VDO Electronic Speedomter Wiring
Posted: Sat Jan 05, 2013 7:01 pm
by krick3tt
Did you buy a 24V unit?
Posted: Sat Jan 05, 2013 9:14 pm
by landy
Yes.
Posted: Wed Jan 09, 2013 9:15 pm
by landy
So nobody has any helpful tips as to wiring this unit?
Posted: Wed Jan 09, 2013 9:31 pm
by Jim LaGuardia
It's pretty straight forward. Find a 24v source with ign on, re use the speedo light wire, run a separate ground wire for the light.
Route and secure wire from sender using same pass through as cable.
Posted: Thu Jan 10, 2013 9:39 pm
by landy
Is there a particular 24v source you'd recommend? Best to splice the new speedo wire in somewhere behind the dash, molex connector, or somewhere else?
Thanks!
Posted: Thu Jan 10, 2013 10:31 pm
by pcolette
You can get 24V for the speedo from circuit breaker #2. Connect a wire to the driver's side (left) terminal of breaker #2 and then to the 24V terminal of the speedo.
Posted: Sat Jan 12, 2013 12:32 am
by landy
Thanks, Paul!
